| Atola - PCB Hot Swap http://forum.hddguru.com/viewtopic.php?f=19&t=19524 |
Page 1 of 1 |
| Author: | Dave@LDF4N6 [ May 26th, 2011, 22:41 ] |
| Post subject: | Atola - PCB Hot Swap |
I want to do a PCB Hot Swap using an Atola Insight but I'm not sure it supports it. The unit has a device->spindown option that when applied appears to stop the motor while retaining power. I assume this function exists to perform a PCB hot swap but I can't find it documented anywhere and I don't want to mess up the unit. Has anyone used the Atola for a PCM hot swap? Regards, Dave |
| Author: | Dmitry Postrigan [ May 28th, 2011, 12:45 ] |
| Post subject: | Re: Atola - PCB Hot Swap |
Hello Dave, Device->Spindown is exactly what you need. Do not worry, the hardware unit has all kinds of power protection (including persistent shorts/over-current). |
