| Bandura Question http://forum.hddguru.com/viewtopic.php?f=19&t=21582 |
Page 1 of 1 |
| Author: | buster80 [ December 30th, 2011, 10:01 ] |
| Post subject: | Bandura Question |
Can you clone source to smaller destination, provided the data on source does not exceed the capacity of the destination? i.e source 500GB (100GB Used) Destination 160GB thanks Andy |
| Author: | pcimage [ December 30th, 2011, 11:10 ] |
| Post subject: | Re: Bandura Question |
buster80 wrote: Can you clone source to smaller destination, provided the data on source does not exceed the capacity of the destination? i.e source 500GB (100GB Used) Destination 160GB thanks Andy That would depend on how the data is distributed on the drive, as I presume the Bandura will clone sector-by-sector. If the data is not fragmented then I would imagine it would work. I don't have a Bandura but have an insight, and tat is how it works on that |
| Author: | buster80 [ December 30th, 2011, 11:11 ] |
merci |
| Author: | Dmitry Postrigan [ December 30th, 2011, 11:45 ] |
Andy, Bandura can copy only occupied sectors from source to target, however, it will not re-size partitions on the fly. In your example it will copy only data (100 GB), however, you would need to use a target drive which is at least as big as the partition on the source drive. |
| Author: | buster80 [ January 1st, 2012, 12:17 ] |
Thanks dmitry |
