 Post subject: Insight Forensic IP Address
PostPosted: January 22nd, 2015, 19:04
Is there an easy way to set the IP address of the Insight Forensic DiskSense unit to whatever I want it to be? I don't want to change my network configuration or use a custom routing just because the default IP can't be changed. I don't see anywhere in the desktop software to do this. Is there a separate utility for it? Or do I have to SSH in and make the change?
http://www.ancilesecurity.com
 Post subject: Re: Insight Forensic IP Address
PostPosted: January 23rd, 2015, 9:41
root of system drive
programs (folder where programs are installed)
Atola Insight Forensic
DSEthernetUpdate.exe
Select any available IP address - which is in the same range of your
Ethernet adapter.
PostPosted: January 23rd, 2015, 10:42
Just what I needed. Thank you falther!
Users browsing this forum: No registered users and 48 guests
