| Port 2 fails to read/write http://forum.hddguru.com/viewtopic.php?f=19&t=33963 |
Page 1 of 1 |
| Author: | hdd_sand [ August 12th, 2016, 15:16 ] |
| Post subject: | Port 2 fails to read/write |
I have two atolas and for some reason both units port 2 fails to r/w, what could it cause this? |
| Author: | Vitaliy Mokosiy [ August 13th, 2016, 1:50 ] |
| Post subject: | Re: Port 2 fails to read/write |
What DiskSense units do you have? What Atola Insight version is in use at your PC? |
| Author: | hdd_sand [ August 15th, 2016, 9:05 ] |
We have V4.4.5809.30644 |
| Author: | Vitaliy Mokosiy [ August 15th, 2016, 9:33 ] |
hdd_sand wrote: We have V4.4.5809.30644 OK, now it is clear. The problem caused the error was already fixed in Atola Insight Forensic 4.5. You may download it if you have an active subscription: http://atola.com/products/insight/download.html In case if you need to renew subscription, please visit this page: http://atola.com/products/insight/subscriptions/ |
| Author: | hdd_sand [ August 15th, 2016, 14:12 ] |
What made Port 2 stop working? the 4.4 update? |
| Author: | Vitaliy Mokosiy [ August 16th, 2016, 5:11 ] |
Yes, speed improvements in 4.4. However, the problem is not that critical as it would seem at first sight. It is only 'Fill or Erase' function that fails for Port 2. Imaging to Port 2 properly works in 4.4. |
