 Post subject: Port 2 fails to read/write
PostPosted: August 12th, 2016, 15:16
I have two atolas and for some reason both units port 2 fails to r/w, what could it cause this?
 Post subject: Re: Port 2 fails to read/write
PostPosted: August 13th, 2016, 1:50
What DiskSense units do you have?
What Atola Insight version is in use at your PC?
Vitaliy Mokosiy
CTO, Atola Technology
Maker of MultiDrive
PostPosted: August 15th, 2016, 9:05
We have V4.4.5809.30644
PostPosted: August 15th, 2016, 9:33
OK, now it is clear. The problem caused the error was already fixed in Atola Insight Forensic 4.5. You may download it if you have an active subscription: http://atola.com/products/insight/download.html
In case if you need to renew subscription, please visit this page: http://atola.com/products/insight/subscriptions/
Vitaliy Mokosiy
Maker of MultiDrive
PostPosted: August 15th, 2016, 14:12
What made Port 2 stop working? the 4.4 update?
PostPosted: August 16th, 2016, 5:11
Yes, speed improvements in 4.4. However, the problem is not that critical as it would seem at first sight. It is only 'Fill or Erase' function that fails for Port 2. Imaging to Port 2 properly works in 4.4.
Vitaliy Mokosiy
Maker of MultiDrive
