 Post subject: errors in primary module
PostPosted: April 17th, 2011, 15:20
Hi
I got a lot of errors in primay modules , so if i backup g-list and p-list moduls then format the SA.
I will solve the probelm ? and get the data back ?
Pls you advice .
 Post subject: Re: errors in primary module
PostPosted: April 17th, 2011, 15:30
with ur SD tools
try to repair from secondary the primary 1st. try it 1st.
and there are modules which are not important means the drive will be accessible and can extract ur data from it
