 Post subject: unlock DRAGFLY series
PostPosted: August 18th, 2011, 22:30
hello,
there isn't any method to unlock DRAGFLY series with WD-DOCTOR without using HOTSWAP because we maybe always have matched donor drive
 Post subject: Re: unlock DRAGFLY series
PostPosted: August 19th, 2011, 10:48
What do you mean 'Unlock' ?? :?:
PostPosted: August 19th, 2011, 12:54
i think he means Password Unlock (02) maybe :idea:
PostPosted: August 19th, 2011, 22:10
I mean disable password,how can I load it with WD-DOCTOR
PostPosted: August 20th, 2011, 13:59
in ur SD-WD use 4.2 (stable)
and u cannot disable it, but can be removed
PostPosted: August 20th, 2011, 23:15
how can I do this with WD-DOCTOR V4-2,program can't load HDD
PostPosted: August 20th, 2011, 23:55
Are you saying you cannot load the HDD ID? Correct me if I am wrong, but if you cannot load ID there is a bigger issue? I am not an SD user, so I have no help past that.
PostPosted: August 21st, 2011, 21:57
any DRAGFLY drive can't be loaded by any version of WD-DOCTOR if the drive locked.
I ask how can I load it and remove password
PostPosted: August 24th, 2011, 1:28
I want to know the method to unlock and in which moduel store pw,is it in ATA mod
PostPosted: August 24th, 2011, 14:00
The only method to access firmware is hot swap,
You have to make modification to parameter module 0002.
