 Post subject: IBM DTNA-22160 protection removal
PostPosted: October 30th, 2011, 4:36
I need help with removing protection on this drive. Drive is operational.
Did someone knows witch two pins on PCB need to be shorted?
Thanks.
Sistrum Data Recovery
http://www.sistrum.mk/en
 Post subject: Re: IBM DTNA-22160 protection removal
PostPosted: October 31st, 2011, 11:55
could u post here IMAGE high res. for the other size
clear image
thnx
PostPosted: October 31st, 2011, 12:02
for a HDD this old you can probably remove in Hot-Swap procedure...
PostPosted: November 1st, 2011, 9:02
Thanks for replay.
For hot swap I don't have a spare drive, will try to find one.
And here is front of PCB.
PostPosted: November 1st, 2011, 11:09
Just read it's internal memory. Password sits in plain text
