 Post subject: WD Doctor support for WD10TMVV
PostPosted: December 10th, 2011, 3:19
Does anyone know if version 6.5 of WD Doctor supports this model. I now have sata access to the drive, power on, and the device becomes ready. However, when I attempt to load from HDD, the drive goes busy. Is this a Royl series? May have done all that soldering work for nothing!
 Post subject: Re: WD Doctor support for WD10TMVV
PostPosted: December 10th, 2011, 23:50
Assuming they exist, I would look for SATA PCBs that use the same Marvell MCU and motor controller and correlate those PCBs against the model numbers of those drives that use them.
Edit: This may be easier:
http://files.hddguru.com/download/PC-30 ... irection=1
