 Post subject: ROM content regenaration fail
PostPosted: December 11th, 2011, 4:36
I got WD32000AAJS-00l7a0 with PCB problem (error status) .
I used donor PCB same model ,after Loading from HDD(load management) with low speed SA Access Method I got the LBA =0 head =3 .
What I done :1-Backup module 0102,0103,0105,0107 and 0109 (Low-Speed SA-Access Method)
2-Generate ROM using the upper modules.
3-After rester I got PCB status error .
3-After reset status (PCB) with HD Doctor for WD v6.0.
status (Error) with HD Doctor for WD v5.0
Pls any Advice
