 Post subject: wd2500aajs-75m0a0 ata module, firmware needed
PostPosted: July 11th, 2012, 0:53
Hello guys I need help in with a compatible ata module (0011) for a wd2500aajs-75m0a0.
Thanks!
 Post subject: Re: wd2500aajs-75m0a0 ata module, firmware needed
PostPosted: July 11th, 2012, 2:17
You need to be much more specific.
What actual version of mod 11 do you need?
I.e. to be compatible with which version ROM?
PostPosted: July 12th, 2012, 7:50
pcimage is right we need the version ...
if you can't check SA modules check ROM file at module 4F as in the picture (the green)
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: July 12th, 2012, 11:13
Firmware version is 000100CS.
Thanks!
PostPosted: July 13th, 2012, 1:51
Please see the attachement
With regards
Sundar
DataCare Services
11.zip [144.81 KiB]
Downloaded 763 times
PostPosted: July 15th, 2012, 22:00
Thanks Sundar,
It looks like the ata module is right but i need also mod 0121 for the same firmware version.
Thanks!
Users browsing this forum: No registered users and 6 guests
