Discussions related to SalvationData products
Hds721010SLA360 SA damaged
May 1st, 2013, 0:24
Hello friends
I have Hitachi drive it come with clicking noise and cannot be recognized by HD Doctor SA A and B are damaged so I was able to access SA C and copy modules and update them to SA A and now I got ready status but it still clicking and I cannot access data I also tray to update NVRAm from identical donor I must mention here that this drive is part of 2 HDD RAID so I have the donor and its good
after all
1- I can read RAM and ROM
2- I can read P list but I cannot read G list
3- I cannot read sector
4- I cannot load from HDD
I still have many bad modules from SA-A
Now the question is witch modules I can update from donors that I don't lose data
thanks
Re: Hds721010SLA360 SA damaged
May 1st, 2013, 2:41
Most importantly you cannot read PSHT, without this you will not get data.
I think you will need to change heads to try and get drive to read from SA-A/B.
Or possibly you have bad sectors in SA preventing you writing the PSHT you got from SA-C to SA-A/B
May 2nd, 2013, 0:54
pcimage wrote:Most importantly you cannot read PSHT, without this you will not get data.
thanks for answering
may question is witch modules can we update from donor than doesn't affect patient data?
can I update PSHT module from donor?
thanks
May 2nd, 2013, 7:49
PSHT is critical for user access data on the patient. Cannot be copied from the donor.
Strongly suggest you follow pcimage's recommendation. Not a good idea to perform any firmware work on a drive with failed heads, which is most likely the case.
May 2nd, 2013, 15:15
PSHT = plist as labtech & pcimage said
