 Post subject: Access to an unnamed file was denied- HD doctor Maxtor 1.45
PostPosted: March 3rd, 2014, 5:43
Hello
I downloaded the new version HD doctor Maxtor 1.45
He can not finish because this message: Access to an unnamed file was denied
under Windows 7
Can you help me
thank you
 Post subject: Re: Access to an unnamed file was denied- HD doctor Maxtor 1
PostPosted: March 3rd, 2014, 19:50
hi,
Do you mean
1) the download couldnt finish ? or
2) the installation couldnt finish? or
3) when running the program, after successful instalation, the program could not finish starting up?
I think if 1, contact SD
if 2, check in eventlog for any errors in the "setup" log, and also look in application logs. Otherwise try some sysinternal tools to monitor file access
if 3) do the same as 2, or try and find exactly which file has an issue.
Have you contacted SD about it?
cheers
PostPosted: March 6th, 2014, 11:25
HaQue wrote:
hi,
Do you mean
cheers
Helo
I found the problem so it's antivirus blocking
Thank you as well
Users browsing this forum: No registered users and 17 guests
