 Post subject: Soft ver error. Looking for a solution
PostPosted: December 26th, 2018, 14:43
Hi gurus!
Tinkering with these tools I just stumbled upon this error from time to time, and lately I figured that it happens because of the updates. Once you update your Sw you can work with it but you cannot get back to work with a previous version if you require it. It is much bothering and an additional limitation though, and happened to me mainly with two doctors: Seagate and Hitachi.
Any idea for fixing this particular issue? ;)
Thanks for your help
 Post subject: Re: Soft ver error. Looking for a solution
PostPosted: December 26th, 2018, 16:30
This is the point spildit :)
For some drives older versions fits better, it is not a rule (i have a very limited experience with sd stuff) but sometimes i managed better using older versions. The last Hitachi sw (7.3) is declared as beta by the developers actually.
Hope to find a way for having this thing fixed
PostPosted: December 26th, 2018, 18:23
Do these updates affect the firmware in the Doctor, or just the host software, or both?
PostPosted: December 26th, 2018, 18:25
Thanks for your reply and i got your point, nonetheless i'm trying to have them sorted out and, fixing issues is a good way for better understanding what we do normally (imo). I worked with ace stuff and actually there are so many things i used to and which i'm not able to replicate without it, but i'm trying to keep up ;)
PostPosted: December 26th, 2018, 18:47
Following my experience I'd say both, but some doctors are more critical than others. Seagate and Hitachi got much more issues in this case :?
PostPosted: December 26th, 2018, 19:56
I'm used to fix problems :) and trying to fix that one doesn't mean that I'm avoiding other tools for working (anyway i don't have those ones, but wdmarvel is a truly good one imo).
Data compass is a fair good imager, just slow as molasses!
PostPosted: January 5th, 2019, 14:11
Hello everybody, I hope this new year got off to a pretty fair start for you all gurus ;)
There's anybody here who can help with this error?
Thanks so much
