Discussions related to SalvationData products
Data Recovery Case by Data Compass Download
February 2nd, 2009, 8:48
Recover data from Hitachi 4240 with physical defects in both the firmware Service Area and Data Area by Data Compass.
http://www.salvationdata.com/downloads/ ... Study3.pdf
Image from the HDD with serious bad sectors in the Data Area by Data Compass.
http://www.salvationdata.com/downloads/ ... Study4.pdf
Recover data from Hitachi with physical defects in data area by DATA COMPASS.
http://www.salvationdata.com/downloads/ ... Study5.pdf
SalvationDATA Data Recovery Example Application: The case study of Data Compass for Image.
http://www.salvationdata.com/downloads/ ... maging.pdf
Case Study: Quick data recovery using HOT SWAP trick in Data Compass
http://www.salvationdata.com/downloads/ ... -trick.pdf
Thank you for your kind concern about SalvationDATA. I hope it will help our clients to use our products more skillfully.
For more details, you can go to http://salvationdata.blogspot.com
Best Regards
Laura
Re: Data Recovery Case by Data Compass Download
February 6th, 2009, 17:11
Dear laura, could you please explain me difference:
"serious bad sectors in the Data Area"
"physical defects in data area"
February 14th, 2009, 2:46
Creator wrote:Dear laura, could you please explain me difference:
Dear laura,
I ask you again,
Explain me please the difference!!!
I don't understand. Maybe you can ask your "gurus"?
February 19th, 2009, 2:04
Dear laura,
I ask you again,
hi,Dear Creator,for my understanding,serious bad sectors means the defects is just the sectors,but physical defects means not only the sectors but including other defects suchs as head,etc.
October 1st, 2009, 19:34
For me it reads like:
Serious bad sector: No ECC/DRQ possible
Physical defects: surface damages (scratches)
The last would really be a wonder on a new drive, but with this old class I can imagine a higher tolerance for slight surface damages.
