| help http://forum.hddguru.com/viewtopic.php?f=20&t=14189 |
Page 1 of 1 |
| Author: | msalsido [ December 9th, 2009, 21:20 ] |
| Post subject: | help |
I miss selecting drive to format, using the low level format tool, but 10 seconds later I notice the mistake and unplug the hard disk. When try to review data nothing can't see no partition. I try to set one again using acronis. but still can't see any of my information. How can I recover my info. Any advice will be appreciated. |
| Author: | ccc [ December 10th, 2009, 3:26 ] |
| Post subject: | Re: help |
If you really want your data back, try to talk to user Beto. He is from Mexico too... Rgds |
| Author: | poehere [ December 10th, 2009, 3:46 ] |
Stop now before you loose all your chance on this one. If anything at all clone your drive to another HDD and do not try to make a new partition or anything else to this drive. This can easily be done by Beto near you and should not be too expensive if you stop playing with this drive now before all your chances are lost for your data |
| Author: | ibach [ May 12th, 2010, 4:14 ] |
first mistake was plugging the disk out... 2nd and worst was making a new partition... writing new data on disk you are trying to save! STUPID! ...You do not need to see the partition at all to save it, what you need to see is the device. use get data back, select the device and let it do extensive scan (look in settings and search for lost files, partitions ect.) wait longtime until scan is finished.... select the data you want to save, and save it on a different HDD. wait for longtime again... check the data... if all is there you can format the disk and use it again. Do not write anything on the disk you are trying to save until you actually save it!!! |
| Author: | craig6928 [ May 16th, 2010, 4:05 ] |
why do it the hard drive get a program called partition magic which will find it |
