SD question spaces
Posted: December 23rd, 2009, 21:45
by Icold
Hi everybody
I have a question about salvation data new HD HPE SP that can support spaces.
I have a seagate 7200.11 but died due click of death.
Can HD HPE SP swap platters with brackets ?
The drive has spaces between the platters (rings AND brackets)
I don’t know If brackets is the right word for it but there are metal thing that cling to 4 corners between the patters.
I’m planning to buy the HD HPE SP so I can swap the platters but when I saw the demo from salvation doing the swap of the hard drive I saw that the dive does not have brackets I the hard drive.
Can someone help me with this question.
Sorry for my bad English is not my first language.
Re: SD question spaces
Posted: December 23rd, 2009, 22:41
by drc
multiple problems here, I will touch briefly on them...
a. your drive probably doesn't need a platter swap
b. from what I have heard the HPE Pro is crappy and does not work at all.
Posted: December 23rd, 2009, 23:14
by Icold
drccsc wrote:multiple problems here, I will touch briefly on them...
http://www.youtube.com/watch?v=G1LnLEV-dk4i saw the you tube video for the drive seagate that i have using hdrc and i looks like it worked on the person In the video but when I saw the expierence from onther on this site users were not happy with the tool.
Do you think that the hd hpe sp and the hp pro are similar quality?
what can you recommend ?
Posted: December 23rd, 2009, 23:45
by pepe
Contact Dobrevjetser, he is from belgium and can help recovering your drive on a probably sympatic price.
Posted: December 25th, 2009, 5:07
by Icold
pepe wrote:Contact Dobrevjetser, he is from belgium and can help recovering your drive on a probably sympatic price.
Can he change the platters to a simular drive because i already went to a company that "recovers data" but it didn"t work
now i wil try to swap them to the same drive that i just baught
Posted: December 27th, 2009, 4:28
by pepe
It's your choice to mess up the whole thing...
that video shows the platters moved from one body do another one. But does not show wether that drive worked after the intervention...
Posted: December 27th, 2009, 8:42
by pcimage
Why do you insist on swapping the platters?
If you have "click of death" then it's very very very unlikely a motor seizure problem.
You have been offered advice by two good pros, but you choose to ignore them.
Good luck!
Posted: May 7th, 2010, 19:00
by ppumkin
Icold wrote:drccsc wrote:multiple problems here, I will touch briefly on them...
I know this thread is dead but in regard to his question
The salvationData tool will not remove this stack. You can use the SD tool to remove a platter from a single platter drive if you REALLY neeed to.. but otherwise dont do it.. like recommended by the gurus.
Personally that tool looks better quality than SD
