Need FW for ST3500630AS
Posted: May 10th, 2010, 8:42
by Kum Ruzvelt
Did someone have FW for this HDD, Barracuda 7200.10 500GB
ST3500630AS
P/N: 9BJ146-568
FW: 3.AFM
Data Code: 08231
Site Code: SU
Re: Need FW for ST3500630AS
Posted: May 10th, 2010, 17:54
by zebong
What happen with the drive ? , why do you need the FW ?
Posted: May 10th, 2010, 21:53
by Kum Ruzvelt
Drive is Busy all the time.
When I power up in Terminal Mode this is output:
Reset
8192k x 16 DRAM
GALAXY - 1_Disk S-7A 05-25-07_13:14
Buzz
I force the disk to F level and in FW Diagnostic i receive this output:
/T
F>
:000000010000 AX' ' " "000155AA-00015729
Age=00 Type=00 MxCyl=0001572A MxHd=00 MxSct=280 BSz=010M TCode=00000000Pgm=00 Trk=00010DC1(00010DC1[000000]).0(0).000(000) Zn=FF Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ntrdy LBA=00000000
Age=00 Type=00 MxCyl=0001572A MxHd=00 MxSct=280 BSz=010M TCode=00000000y
PhysCyl GrayCyl
1st Sys Cyl 000155AA 00016FBD
1st 0 Offset Cyl 000155B4 00016FC7
1st App Code Cyl 000155C0 00016FD3
2nd App Code Cyl 000155C2 00016FD5
2nd 0 Offset Cyl 000155CE 00016FE1
3rd App Code Cyl 000155DA 00016FED
4th App Code Cyl 000155DC 00016FEF
Last System Cyl 000185CF 00019FE2
F>/2
F>x
Command Inactive - No VALID Cert Code Detected
F>
Posted: May 11th, 2010, 5:22
by hddguy
Kum Ruzvelt wrote:Drive is Busy all the time.
Reset
8192k x 16 DRAM
Buzz
You see nothing after 'Buzz'? Is disk spinning?
Posted: May 11th, 2010, 7:07
by Kum Ruzvelt
Disk doesn’t spin. When I turn the power on, I can fill like vibration and buzzing noise and after 20 seconds one beep.
Posted: May 11th, 2010, 7:15
by unknown
Kum Ruzvelt wrote:Disk doesn’t spin. When I turn the power on, I can fill like vibration and buzzing noise and after 20 seconds one beep.
Sounds like stuck heads to platter or motor jammed.
Posted: May 11th, 2010, 8:11
by Kum Ruzvelt
How much force I need you use if is head stuck? This will be my first time for this, maybe will be painful
Thanks for your support, this is incredible good forum.
Posted: May 11th, 2010, 8:16
by zebong
you do not need too much force.
but i must tell you that you can have some errors with that situation "pendind error" or similiar.
Good Luck.
Posted: May 11th, 2010, 8:17
by zebong
ohh
i did not see that was a 7200.10 ....
ops...
i have made a tool for that problem.
Posted: May 11th, 2010, 9:03
by Kum Ruzvelt
zebong, can you give me more info about your tool.
Posted: May 11th, 2010, 9:28
by zebong
Sorry can not give any details.
Posted: May 11th, 2010, 9:33
by Kum Ruzvelt
OK, I completely understand you. I will inform you about results.
Posted: May 11th, 2010, 9:34
by drc
90% of time it is not heads stuck, but platters stuck. This job needs pro help.
Posted: May 11th, 2010, 9:36
by unknown
drc wrote:90% of time it is not heads stuck, but platters stuck. This job needs pro help.
Agree with drc.
Posted: May 11th, 2010, 11:22
by Kum Ruzvelt
I agree with you guys. This is my practice drive.
