May 3rd, 2010, 23:13
May 4th, 2010, 4:01
May 5th, 2010, 15:17
May 7th, 2010, 15:58
May 11th, 2010, 22:11
ppumkin wrote:Regarding the sparking of the dc jack
I just bought the DataCompass and the same thing happens. When you plug it in sparks came out as if it was shorting out
Im in the UK 220volt.
The unit uses normal laptop 19v centre pin + power unit. It seemed strange to me too and only saw this type of effect on reverse polarity appliances.
It could be possible that the wiring inside the DC is reversed. It wont damage your hardware and it seems that USB negative and Mains negative is isolated so it should not cause damage to your PC.
May 25th, 2010, 10:10
May 25th, 2010, 20:49
May 26th, 2010, 2:31
May 26th, 2010, 2:50
May 26th, 2010, 17:38
May 26th, 2010, 17:56
May 26th, 2010, 21:33
poehere wrote:Only way I find it does not spark is this one. Take the end of your power adaptor and separate them. Plug half into electricity and half into drive set it all up then attach them together and then add on usb. Otherwise it sparks all the time on this one. Only good on small drives so not a lot of use on this tool now considering drives are more then 500gb
