 Post subject: Need firmware WDC WD1600AAJB-00J3A0
PostPosted: July 30th, 2010, 10:34
Hi guys, I need firmware for
Thank you in advance
 Post subject: Re: Need firmware WDC WD1600AAJB-00J3A0
PostPosted: August 20th, 2010, 17:43
SN?
PostPosted: August 26th, 2010, 5:37
If it does not help let me know ..send me . I have anothers that might work.
WDC WD1600AAJB-00J3A001. 03E01.rar [5.31 MiB]
Downloaded 1510 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: January 7th, 2011, 22:06
I did not know how I set the password. I was trying to give a zero-fill using wd utilities from Hiren boot cd. At one point I created a partition using the WD utilities setup and it creates me a 137GB partitionsetting LBA to 24(I think). After some struggle I managed to set the lba to 48 I set after I did it (I donțt remember what program I used) with MHDD I discovered that the HDD is password protected.
Currently WD utiities I do not work anymore, when I try to start it, I see the pointer for about 2 seconds and it closes.
Also my(gigabyte) motherboard may saved a copy of bios on it.
Searching on internet I discovered that a rewrite of the firmware may resolve the problem.
Help pls.
sry for my english.
