Discussions related to SalvationData products
September 27th, 2010, 3:05
Hi All,
Salvationdata Maxtor 6E drives hang in Surface Test 0175 for long time,
Changed group2 module,and selfscan modules 13,14,etc.with other same donor.
Can any one advice how to fix this error?
Sadiq
September 27th, 2010, 15:08
If surface is really bad there's nothing to do.
September 27th, 2010, 16:23
Agree.
If surface is good enough, SS should be run smoothly.
If surface have problems, you should do something manually, or simple forget this drive like an usable one, use it as donor instead.
Janos
