Discussions related to SalvationData products
WD2500bevs-26vat0
August 20th, 2010, 19:37
I have been bashing my brains with this hdd.
Initially plugged into DC and it went Ready- opened explorer read the partitions i could see the file structure selected the files and started to recover- after 1s sector(PIO) hard drive buzzed and did not respond.
Plugged in HD doctor. did not go ready-- tried many times- spins up 2 minutes down and twice like that.
I got it to PCB mode and read the ROM- the head map is 0,2,3,4 - is that normal?
I checked with donor and its head map is 1,2,3,4
After messing about with res file conversions and all that i tried the hot swap procedure. read patient p/glist write to donor.
The drive went ready for a while and i could read a few modules of the patient and then died completely
Using the donor pcb the drive spins up but clicks- and cannot access data.
Another thing is i cannot find the proper PCB donor based on FW xxVAxx ..
Drive does not spin up with original PCB now- stays in PCB mode in HD Doctor. can only read/write rom..
Any tips on how to rule out PCB or Heads.
Thanks for looking and for any helpful replies.
Re: WD2500bevs-26vat0
August 21st, 2010, 4:53
good work.
This case was easy, but now it is not. :)
Seek for professional help (and for professional tools) ....
Janos
August 21st, 2010, 5:06
PS
But my psychiatrist no longer want to help me.I am driving him nuts.
