| Need FW for ST9500325AS http://forum.hddguru.com/viewtopic.php?f=20&t=16993 |
Page 1 of 1 |
| Author: | Kum Ruzvelt [ September 14th, 2010, 0:40 ] |
| Post subject: | Need FW for ST9500325AS |
Did some one have FW for this HDD: Momentus 5400.6 model: ST9500325AS s/n: 5VE03SZY P/N: 9HH134-566 FW: 0001BSM1 I can read FW under 7200.11/12 on HD Doctor. BIOS and Windows recognize the drive but unable to access. Victoria report IDNF on all sectors. Thanks. |
| Author: | hddguy [ September 14th, 2010, 6:07 ] |
| Post subject: | Re: Need FW for ST9500325AS |
Can you read any of the surface,maybe in the first thousand LBA? |
| Author: | Kum Ruzvelt [ September 14th, 2010, 6:31 ] |
On DC I check sector 63 and I so info about NTFS, but on HD Doctor nothing. And i can read most of the FW modules. |
| Author: | pcimage [ September 14th, 2010, 7:22 ] |
I bet LBA up to a certain number are accessible, then nothing after, right? Sometimes they are readable up to several million before blocked, but I had one which would only read up to sector 11 before nothing. FW won't help you. |
| Author: | Kum Ruzvelt [ September 14th, 2010, 12:18 ] |
Thanks pcimage, any solution for this problem problem. |
| Author: | pcimage [ September 14th, 2010, 13:58 ] |
Yes there is a solution for this problem in most cases. I know it and have solved many of these. But it's difficult, time consuming and not for sharing, sorry. |
| Author: | Kum Ruzvelt [ September 14th, 2010, 22:34 ] |
No problem pcimage, I wil continue with work on this drive. |
