HDD GURU FORUMS
http://forum.hddguru.com/
Maxtor Selfscan Hangs
http://forum.hddguru.com/viewtopic.php?f=20&t=17149
Page 1 of 1
Author:  sadiq005 [ September 27th, 2010, 3:05 ]
Post subject:  Maxtor Selfscan Hangs
Hi All,
Salvationdata Maxtor 6E drives hang in Surface Test 0175 for long time,
Changed group2 module,and selfscan modules 13,14,etc.with other same donor.
Can any one advice how to fix this error?
Sadiq
Author:  BlackST [ September 27th, 2010, 15:08 ]
Post subject:  Re: Maxtor Selfscan Hangs
If surface is really bad there's nothing to do.
Author:  N.C. [ September 27th, 2010, 16:23 ]
Agree.
If surface is good enough, SS should be run smoothly.
If surface have problems, you should do something manually, or simple forget this drive like an usable one, use it as donor instead.
Janos
http://www.phpbb.com/
