Suspicous connections from HD Doctor for Seagate
http://forum.hddguru.com/viewtopic.php?f=20&t=18765
Author:  Cris [ March 7th, 2011, 8:29 ]
Post subject:  Suspicous connections from HD Doctor for Seagate
Maybe I'm a little paranoid, but I find it strange that some of the components of the software from SalvationData are detected as malware by some virus scanners.
Anyway, I decided to run "netstat -b 1" whilst running the software to see if it was making any connections, and it wasn't I believe until I selected the "About" tab.
Some of these look suspicious
box675.bluehost.com resolves to the same IP address as http://www.salvationdata.com so that is OK, but some of the other connections such as hn.kd.smx.adsl is of concern. Has anyone conducted a proper security analysis of the software?
I have also attached some virus scans of some of the files:
HD Doctor for Seagate.exe - main executable of program:
HD Doctor for Seagate.pdf
autorun.exe - file on disc:
autorun.pdf
seg_USB_DLL.dll - dll file that came with latest upgrade:
seg_USB_DLL.pdf
Active Connections
Proto Local Address Foreign Address State PID
TCP temp:1435 box675.bluehost.com:http SYN_SENT 660
[HD Doctor for Seagate.exe]
Active Connections
TCP temp:1437 ip199.hichina.com:http SYN_SENT 660
TCP temp:1436 ip199.hichina.com:http ESTABLISHED 660
Active Connections
TCP temp:1437 ip199.hichina.com:http ESTABLISHED 660
TCP temp:1438 74.125.237.33:http ESTABLISHED 660
TCP temp:1439 123.125.115.126:http FIN_WAIT_1 660
Active Connections
TCP temp:1444 123.125.114.41:http SYN_SENT 660
TCP temp:1442 box675.bluehost.com:http ESTABLISHED 660
TCP temp:1443 box675.bluehost.com:http ESTABLISHED 660
TCP temp:1440 123.125.115.126:http FIN_WAIT_1 660
TCP temp:1439 123.125.115.126:http TIME_WAIT 0
Active Connections
TCP temp:1449 counter.statcounter.com:http SYN_SENT 660
TCP temp:1448 hn.kd.smx.adsl:http ESTABLISHED 660
TCP temp:1445 hn.kd.smx.adsl:http LAST_ACK 660
TCP temp:1446 123.125.114.41:http LAST_ACK 660
TCP temp:1447 123.125.114.41:http LAST_ACK 660
TCP temp:1440 123.125.115.126:http TIME_WAIT 0
Active Connections
TCP temp:1450 222.245.135.171:82 ESTABLISHED 660
TCP temp:1451 222.245.135.171:82 ESTABLISHED 660
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
TCP temp:1442 box675.bluehost.com:http CLOSE_WAIT 660
Active Connections
TCP temp:1443 box675.bluehost.com:http CLOSE_WAIT 660
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Active Connections
Author:  pclab [ March 8th, 2011, 6:40 ]
Post subject:  Re: Suspicous connections from HD Doctor for Seagate
Disconnect it from the Internet. I'm not worried about that at all.
Author:  einstein9 [ March 8th, 2011, 9:11 ]
Agree with you here. got the same with my WD/Seagate both or i can say all SD tools has this problem
but @ the end of the day you are fixing those hdd there is no important data inside which matters i think except resources.
:mrgreen:
Author:  craig6928 [ March 9th, 2011, 0:54 ]
talk back with salvation data they want to know what type of drive your working on etc
a lot of data recovery tools have talk back built into it
to improve services
just block it from connecting or infact dont have a pc system connecting to the net
Author:  irs [ March 10th, 2011, 9:30 ]
i normally use not to connect any DR machine in internet for security and privacy matters ...
Author:  BlackST [ March 10th, 2011, 10:07 ]
Disconnect from net or put behind properly configured HW FIREWALL the DR devices. Simple.
