Discussions related to SalvationData products
FW Request Maxtor DiamondMax Plus 8 6E040L0STD NAR61HAO
April 12th, 2011, 16:02
Hi, Everybody...
I need fw for a maxtor hard drive of 40 gb....
DiamondMax Plus 8
6E040L0STD
CODE NAR61HAO
Serial E924W4JE...
LBA: 80293248
This Drive show status ready, but I can't see any parameters... I hope someone can help me.... I want to try restore the firmware but I don't have the Sa-C boot mod... :(
If someone have it, I will appreciate if can help me...
Thanks Alot...
Re: FW Request Maxtor DiamondMax Plus 8 6E040L0STD NAR61HAO
April 13th, 2011, 6:09
to fix loosing data or you need data from it?
April 13th, 2011, 17:33
I need the data...
the model is 6E040L0711205
CODE: NAR61HA0
SERIAL E924W4JE
LBA 80293248
I have Nar61590 but not this model... :(
Thanks Alot....
April 13th, 2011, 18:24
Here you go...
http://files.hddguru.com/download/PC-30 ... E-KMBA.rar
April 13th, 2011, 19:55
Thanks N.C., for your help
But I don't have pc-3k Yet,
I need the file boot.cod ....., when i connect the HDD and turn on, in HD Doctor for maxtor, this drive show status ready, but none parameters.... show N40P and NAR63G4Z, But the CODE in label is NAR61HAO... I can't access nothing, not p-list, not modules...nothing....
just NAR63G4Z and LBA 0
Therefore, I want to try to repair the fw problem, but I don't have the file boot.cod.... :(
April 13th, 2011, 20:23
Hi, do you have login access to Salvation forum yet? There are some there. The closest I have is 6E040L0-NAR61590-E1JS... Maybe PC-3000 file will work, have not had chance to test.
April 14th, 2011, 1:23
Yes, I have access to salvation data forum, and i search for this fw, but i can't find it... :(... nearest is NAr61590... i search in the forum, but today I will post a message to see if something have this fw....and can help me
Thanks....
April 14th, 2011, 11:55
if you want SA access (only), you can use any loader (or boot code) wich matches this HW from any NAR61xxx firmware.
April 17th, 2011, 16:37
Thanks Friends...
Now I have access to firmware.... now show status ready and I can see the parameters....
MAXTOR 6E040L0 NAR61HA0 AND LBA correctly... I see the Modules but if I save SA Primary, Have error In this Modules....18,27,34,36,40,52,65,99,112,152,167.....
If I save fw in SA Secondary...have error in this Modules.... 0-22,27,34-45,51, 65-67,70,71,73-99,104-107,116-119,121-146,155-157,159-164 and 167-173....In fact many, many modules damages....
If I save groups have error in this groups...0,1,2,3,5,6,7.... 4 ,8 y 9 are ok...
If I save ram is ok....
If I try to save ROM.... program is Freeze...... ... and send me access denied...
I attach pictures of errors...
I try to upload good firmware, but i can't :(.... I use to upload firmware 6E040LO NAR61HAO E92....)... i try too upload only damage modules... if I try to see sectors... show only 6666...and send error....
If someone can give me any idea how to fix it?
Thanks in advance....
Errors in 6E040L0 NAR61HA0.rar
Errors in Nar61HAO
(480.06 KiB) Downloaded 843 times
