Any advice to fix P-List
http://forum.hddguru.com/viewtopic.php?f=20&t=19535
Author:  redseaksa [ May 27th, 2011, 12:02 ]
Post subject:  Any advice to fix P-List
Hi
I got WD160gb with errors in P-List( head 0 and head 1)
Any advice to fix this problem to recover data?
I' would appreciate any help.
Note :Witch track No. is related to p-list ?
Thank you.
Author:  labtech [ May 27th, 2011, 13:01 ]
Post subject:  Re: Any advice to fix P-List
Does the translator module have errors as well?
Author:  redseaksa [ May 27th, 2011, 17:47 ]
Thank you for reply
No errors in translator
Author:  redseaksa [ May 28th, 2011, 3:17 ]
redseaksa wrote:
Thank you for reply
Note: translator regeneration failed
Author:  smartinfotech [ August 31st, 2011, 6:03 ]
redseaksa wrote:
Hi
Thank you.
bro just check secondary modules if secondary module good then just "AUTO REPAIR" fuction to repair bad module from good one and do translator regenerator.
power off and on go to view sector check 0 and 63 sector. and reply here what happend.
Author:  irs [ September 12th, 2011, 9:53 ]
hi
you say error head 0 and 1 so both copies are corrupted, you can try to open the corrupted modules and check if are corrupted in different parts you can rebuild it, or can be rebuilt from selfscan logs .. but i think wd doctor doesen't have this option
bye
Luca
