| unlock DRAGFLY series http://forum.hddguru.com/viewtopic.php?f=20&t=20322 |
Page 1 of 1 |
| Author: | imtra84 [ August 18th, 2011, 22:30 ] |
| Post subject: | unlock DRAGFLY series |
hello, there isn't any method to unlock DRAGFLY series with WD-DOCTOR without using HOTSWAP because we maybe always have matched donor drive |
| Author: | hddguy [ August 19th, 2011, 10:48 ] |
| Post subject: | Re: unlock DRAGFLY series |
What do you mean 'Unlock' ?? |
| Author: | einstein9 [ August 19th, 2011, 12:54 ] |
hddguy wrote: What do you mean 'Unlock' ?? i think he means Password Unlock (02) maybe |
| Author: | imtra84 [ August 19th, 2011, 22:10 ] |
I mean disable password,how can I load it with WD-DOCTOR |
| Author: | einstein9 [ August 20th, 2011, 13:59 ] |
imtra84 wrote: I mean disable password,how can I load it with WD-DOCTOR in ur SD-WD use 4.2 (stable) and u cannot disable it, but can be removed |
| Author: | imtra84 [ August 20th, 2011, 23:15 ] |
how can I do this with WD-DOCTOR V4-2,program can't load HDD |
| Author: | Agent [ August 20th, 2011, 23:55 ] |
Are you saying you cannot load the HDD ID? Correct me if I am wrong, but if you cannot load ID there is a bigger issue? I am not an SD user, so I have no help past that. |
| Author: | imtra84 [ August 21st, 2011, 21:57 ] |
any DRAGFLY drive can't be loaded by any version of WD-DOCTOR if the drive locked. I ask how can I load it and remove password |
| Author: | imtra84 [ August 24th, 2011, 1:28 ] |
I want to know the method to unlock and in which moduel store pw,is it in ATA mod |
| Author: | Hary [ August 24th, 2011, 14:00 ] |
The only method to access firmware is hot swap, You have to make modification to parameter module 0002. |
