WD5000AAKS-22TMA0
http://forum.hddguru.com/viewtopic.php?f=20&t=20434
Author:  pclab [ September 2nd, 2011, 6:16 ]
Post subject:  WD5000AAKS-22TMA0
Hello
I have this drive wich came with a burned diode. I removed it and the HD already spins.
But now, when trying to work with it, it makes a few clicks (not loud clicks) and spins down. Can't be detected.
When I try to see the head map, the heads start at 2-3-4-5, don't start from 0, as you can see from the picture.
What can this be?
Author:  einstein9 [ September 3rd, 2011, 8:46 ]
Post subject:  Re: WD5000AAKS-22TMA0
probably one/more heads damage
Author:  irs [ September 12th, 2011, 9:49 ]
head map starting from 2 is normal on some WD families, if i remember well tornado family is like that.
Bye
Luca
Author:  pcimage [ September 12th, 2011, 16:37 ]
Real head map on this drive is 2,3,4,5,6,7
So as you can see the SD tool does not support this model properly.
Quiet clicking followed by spin down is classic symptom of bad head(s).
Member dmarques is in Portugal and comes highly recommended.
Author:  einstein9 [ September 13th, 2011, 15:20 ]
from the day i knew this SD-WD up till now, they never fixed the 103 reading in wd 2.5
i hate it really, and many bugs reported and never been fixed
but @ the end of the day, it fixes few problems :wink:
