 Post subject: Seagate Barracuda LP (ST31000520AS) Translator Regeneraton
PostPosted: September 16th, 2011, 3:49
I'm having a problem with a Seagate Barracuda LP ST31000520AS.
After repairing the FW (The normal way m0,2,2,,,,,22 and N1 etc.) The drive can image from sector 0 to 150,000,000 with no problem but cannot read any sector there after. To my knowledge this is a translator problem.
Now my question: 1.) Can Disk Doctor for Seagate correct the problem? There is the option under "new feature for 7200.11" then "Translator Regeneration" Most important: 2.) if i try this option, could it cause data loss?
 Post subject: Re: Seagate Barracuda LP (ST31000520AS) Translator Regenerat
PostPosted: September 16th, 2011, 6:25
No need to reply thank you.
I Fixed the problem with PC3000UDMA using Translator Recovery Option.
