IBM DTNA-22160 protection removal
http://forum.hddguru.com/viewtopic.php?f=20&t=20985
Author:  Kum Ruzvelt [ October 30th, 2011, 4:36 ]
Post subject:  IBM DTNA-22160 protection removal
I need help with removing protection on this drive. Drive is operational.
Did someone knows witch two pins on PCB need to be shorted?
Thanks.
Author:  einstein9 [ October 31st, 2011, 11:55 ]
Post subject:  Re: IBM DTNA-22160 protection removal
could u post here IMAGE high res. for the other size
clear image
thnx
Author:  hddguy [ October 31st, 2011, 12:02 ]
for a HDD this old you can probably remove in Hot-Swap procedure...
Author:  Kum Ruzvelt [ November 1st, 2011, 9:02 ]
Thanks for replay.
For hot swap I don't have a spare drive, will try to find one.
And here is front of PCB.
Author:  guru [ November 1st, 2011, 11:09 ]
Just read it's internal memory. Password sits in plain text
