 Post subject: Hitachi HTS543232L9SA00
PostPosted: November 22nd, 2011, 6:38
Hi
I need this FW.
Does someone have it?
ACELab partner
 Post subject: Re: Hitachi HTS543232L9SA00
PostPosted: November 22nd, 2011, 9:56
I looked but... :(
PostPosted: November 22nd, 2011, 14:08
northwind wrote:
I looked but... :(
Thanks :wink: :wink:
ACELab partner
PostPosted: November 22nd, 2011, 18:02
i think this is quite a common drive. I'm surprised i don't have these resources. Someone will have it for you i'm sure :)
PostPosted: November 22nd, 2011, 18:42
Actually no. I have searched allot and no one have it.
ACELab partner
PostPosted: November 24th, 2011, 11:33
Here you go...
Hitachi HTS543232L9SA00-FB4OC43C-090630FBD406CEGHH4NC.rar [501.23 KiB]
Downloaded 977 times
PostPosted: January 29th, 2012, 10:35
hello folks,
I also have one of these drives, what program should I use to update the firmware ?
many thanks indeed !
PostPosted: January 29th, 2012, 18:13
ethos wrote:
hello folks,
What do you mean by "update the firmware"? Why would you want to do that?
Do you mean "repair the firmware?
If yes then you need something like pc3000 UDMA at about $10,000 plus know how to use it.
What's the actual problem with your drive?
PostPosted: January 30th, 2012, 6:11
Yes, repair the firmware I would imagine.
I have this Hitachi HTS543232L9SA00 drive and it appears to be working in an erratic way, I thought it
could be corrupted firmware. Erratic in that, it was producing arbitrary errors causing blue screens and
in took a longer than expected time (about 24 hours for 100GB or so) to copy across to another device, the data stored on it.
Zero filling the drive with # dd if=/dev/zero of=/dev/sd[x,y] resulted in non verbose ioctl errors, basically 'quietly' locking that process.
Its just out of warranty and has never had a serious knock or anything, afaik and thus I have a (not strong) hunch that it could have
been caused by some sort of malware.
I did a quick search and found this thread, seeing that someone else requested firmware for such a device,
one assumes its possible to re-write or update the firmware (as with many other devices).
So, there is, to your knowledge no program that facilitates firmware repair without some sort of hardware implementation ?
many thanks for your time.
PostPosted: January 30th, 2012, 13:58
If you are trying to repair the drive, forget it. With the money you need to buy the tools, you can buy dozens of drives.
ACELab partner
PostPosted: January 30th, 2012, 16:22
Not a firmware issue, the drive is dying by the sound of it. Bad sectors.
Just buy a new one.
PostPosted: January 30th, 2012, 16:28
Try a comprehensive SMART diagnostic. Look for reallocated, pending, or uncorrectable sectors.
HD Sentinel (DOS / Windows / Linux):
http://www.hdsentinel.com/
HDDScan for Windows:
http://hddscan.com/
See this article for SMART info:
http://en.wikipedia.org/wiki/S.M.A.R.T.
