 Post subject: SD Head Replacement Toolkit
PostPosted: December 22nd, 2011, 4:25
SD head replacement toolkit is one perfect match of another SD popular clean room data recovery tool-HD HPE PRO for high success rate head replacement and platter swap.
New SD Head Replacement Toolkit
High-precision injection moulding + advanced research in different hard drives’ inner physical structure
SD head replacement toolkit contains two parts: 16 different types of head combs supporting different brands of hard drives’ multiple heads replacement and 48 locking pins with customized sprung gaps to fix the head combs and head arms and add to the head replacement success rate.
What is SD head replacement toolkit designed for?
When it’s confirmed to be head damage or other hard drive physical damages which require you to perform the head replacement, SD head replacement toolkit is to ensure the correct and successful operation of head replacement.
Features & Functions
* Practical Applications:Professional and friendly Simultaneous design to work on multiple heads separation at the same time; Consistent design to physically and equally separate the heads;
* High Efficiency & Accuracy: To ensure the easy move in/out of the parking zones during the head replacement operation (installing/uninstalling the heads);
* Physical effective head separation: Maximize the security of head replacement while the ability of tremor resistance is increased;
* Fix effectively: Fix the head arms and head replacement toolkit (head combs) by inserting the locking pins into the arms;
* Fix heads contact: Outer-parking-designed head replacement toolkit is able to separate the heads successfully;
* Features of SD head replacement toolkit: Outstanding performance, tested chemical stability and good wearing resistance, to be used for long between -20℃ and 85℃;
* Manage Donor Heads Effectively: Easily keep and manage your donor heads with SD head replacement toolkit so that you don’t bother each time installing the donor heads back to the hard drives;
* Cost Control: the operation times of head installing and uninstalling are ultimately reduced with the help of SD head replacement toolkit, so that the chance of accidental head damage becomes slimmer and finally the cost of acquiring and managing donor heads is maximally reduced.
Purchasing Note:
1, Before you can use SD new head comb suite very well, you need to have some experience of head replacement or have used familiar head replacement products or you need more practice on the toolkit;
2, Before you use the head replacement toolkit for head replacement, you need to use HD HPE PRO to disassemble the hard drives and remove some components such as the cover, HSA stopper, top magnet, etc;
3, Remember to work with SD head replacement toolkit, you should have clean room environment or at least one qualified clean bench.
 Post subject: Re: SD Head Replacement Toolkit
PostPosted: December 23rd, 2011, 8:08
Been there and done that with HDRC toolset. (which is 100% the same! )
Total waste of time and money in my opinion.
PostPosted: December 23rd, 2011, 10:16
I'd be interested to hear from anyone that's purchased and used these....and how they compare to the HDRC "offerings". Also if they are a match for the CPR tool set (which I doubt). I think we already know that they're not in the same league as the HDD Surgery tools, but these combs have their uses, and can often be adapted, and used on other drive/head types.
Just interested..... :)
http://www.eadr.co.uk
PostPosted: December 23rd, 2011, 11:00
SD New Head Comb Suite is more cheaper than HRDC
PostPosted: December 23rd, 2011, 20:16
If you have a few spare mins and some creativity you can make these fairly quickly and for less than a dollar. I doubt HDRC and SD will refund your money when you figure out that the plastic they use is to heavy and fits poorly. I burned my HDRC head combs in our fireplace last year with some choice words after they ruined a good head stack. They were the most useless tools I ever purchased. Never again...
PostPosted: December 27th, 2011, 3:02
Yeah, HDRC is useless and i refuse to use it, but i'll try some cheap and soft material-made tools from SD. If it works, i will recommend it to you guys.
PostPosted: May 11th, 2012, 13:47
Somebody have bought or tested SD it? I would like hear the expert's opinion :D
