wd2500aajs-75m0a0 ata module, firmware needed
Posted: July 11th, 2012, 0:53
by hddscom
Hello guys I need help in with a compatible ata module (0011) for a wd2500aajs-75m0a0.
Thanks!
Re: wd2500aajs-75m0a0 ata module, firmware needed
Posted: July 11th, 2012, 2:17
by pcimage
You need to be much more specific.
What actual version of mod 11 do you need?
I.e. to be compatible with which version ROM?
Posted: July 12th, 2012, 7:50
by irs
pcimage is right we need the version ...
if you can't check SA modules check ROM file at module 4F as in the picture (the green)
Posted: July 12th, 2012, 11:13
by hddscom
Firmware version is 000100CS.
Thanks!
Posted: July 13th, 2012, 1:51
by datacare
Please see the attachement
With regards
Sundar
DataCare Services
Posted: July 15th, 2012, 22:00
by hddscom
Thanks Sundar,
It looks like the ata module is right but i need also mod 0121 for the same firmware version.
Thanks!
