| SEAGATE FIRMWARE ISSUE http://forum.hddguru.com/viewtopic.php?f=20&t=23459 |
Page 1 of 1 |
| Author: | datacare [ July 13th, 2012, 1:40 ] |
| Post subject: | SEAGATE FIRMWARE ISSUE |
Is it possible to repair the following problem through Salvation HD Doctor for Seagate Model : ST_M13FQBL Serial : QNR_BFW Firmware : 03171104 Capacity : 3.86 GB (8 089 950) Original Model is ST3500413AS-FIRMWARE JC4B I already tried with pc3000udma but there is no use With regards Sundar |
| Author: | pcimage [ July 13th, 2012, 2:25 ] |
| Post subject: | Re: SEAGATE FIRMWARE ISSUE |
datacare wrote: Model : ST_M13FQBL Serial : QNR_BFW Firmware : 03171104 Capacity : 3.86 GB (8 089 950) Means drive cannot read SA, most likely heads are bad. |
| Author: | northwind [ July 13th, 2012, 3:39 ] |
pcimage wrote: most likely heads are bad.
| Author: | labtech [ July 13th, 2012, 8:40 ] |
After powering the drive on, it spins, and then what? It stays spinning until you power it off? |
| Author: | darkforce1 [ July 14th, 2012, 15:04 ] |
bad head |
