 Post subject: Problem when exchange PCB
PostPosted: November 25th, 2012, 10:48
Hi guy ,
I have two HDD : WD1600AAJS-00B4A0 & WD16AAJS-00M0A0 , i dowdload HDD with SA low_speed. I exchanged PCB and back up moden 102,103,105,107,109 ( it 's ok) , then i run genereta ROM but not ok . I try to run Hot Swap , it's not ok too . what is problem ? Please show me solution for this .
 Post subject: Re: Problem when exchange PCB
PostPosted: November 26th, 2012, 5:14
What do you need? Data or drive? What's the initial problem of the drive?
ACELab partner
PostPosted: November 29th, 2012, 7:14
I also had a similar problem with model 32AAKS-00L9A0.
I have FW and ROM itself, after servo Rewrite, HDD suddenly no longer visible.
SA Low speed, i autorepair all the other modules it is ok, then backup 102,103,105,107,109 mod and generate ROM, it can not be completed. I tried to add a few more times still no results.
I checked the Head 0, 1 it is good , WinHex compare the length of the 5 modules is ok.
I changed the another PCB donors, the situation remains the same. I'm really tired generate ROM.
Any idea yet for my case, it is highly appreciated.
Regards!
PostPosted: November 30th, 2012, 7:07
What exactly do you mean by this? what did you write?
Probably half of your problem is the tool you choose...
