 Post subject: Model : ST9500325AS
PostPosted: April 25th, 2013, 12:39
Hi
I have following HDD.
Model : ST9500325AS
Serial : 5VEFCCXR
Firmware : 0002BSM1
Capacity : 465.76 GB (976 773 168)
if i starts to make image of this hdd,i starts copying but after some time its stops reading LBA(Yellow),then i if repowered 2-3 times copies some time again.
WY05D7.BSM1.DA99LL.0002BSM1
Requesting FW Pkg ver ........
Collecting Sys Files information...
ID Len
0 2 Reserved Defect Table (SA defect table)
1 2 Drive Information File (DIF)
2 16 Performance Parameter File (PPF)
3 1870 Primary Defect File (P-List))
4 9 Servo Adaptive Parameter File (SAP)
5 4 Manufacturing Information File (MIF)
6 85 Read Adaptive Parameters File (RAP)
7 1 Controller Adaptive Parameters File (CAP)
8 2400
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
C 64000 Serial Port Test Results File (Self Scan Log)
D 160
E 432 Data Integrity Check (DIC), HEAD 0
F 223 DIC Dummy File
13 8 Disc Registry File (settings, security, etc)
15 100 BGMS File (Directed Offline Scan)
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
1D 128 Physical Overlay File 0
1E 128 Physical Overlay File 1
1F 640 Physical Overlay File 2
22 80 Drive Self Test (DST), Head 0
23 80 Drive Self Test (DST), Head 1
24 80 Drive Self Test (DST), Head 2
25 80 Drive Self Test (DST), Head 3
26 80 Drive Self Test (DST), Head 4
27 80 Drive Self Test (DST), Head 5
28 80 Drive Self Test (DST), Head 6
29 80 Drive Self Test (DST), Head 7
2A 9 Saved Mode Pages (HDD settings)
2B 535 R/W Operating Parameters (translator, etc)
2C 432 Data Integrity Check (DIC), HEAD 1
2D 432 Data Integrity Check (DIC), HEAD 2
2E 432 Data Integrity Check (DIC), HEAD 3
2F 432 Data Integrity Check (DIC), HEAD 4
30 432 Data Integrity Check (DIC), HEAD 5
31 432 Data Integrity Check (DIC), HEAD 6
32 432 Data Integrity Check (DIC), HEAD 7
33 4576
34 640 Packed CONGEN XML definition
35 26 SMART Data
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
ID MemOffs Len
0 6020100 43520 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4000000 4096 Servo Adaptive Parameter File (SAP)
5 6C000 81920 Servo Firmware Table
8 10070000 948
A 60A1970 1024 Seek Profile
12 100D4000 104
13 60AC9F0 768 Dependent Zone Table for User Area
14 60ACCF0 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60AB7D8 4632 Dependent Zone Group Tables for User Area
1C 60AB698 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020380 3216 Zone Format Parameters File
RAM:
ID MemOffs Len
2 60201F0 400 Zone Table
6 227840 40996 Servo Flaw Table
8 10070000 948
12 100D4000 104
16 6020100 32 Drive Configuration Table
17 6022A60 1616 Temperature Control Configuration
1F 6144678 1728 RW working user preamp table
20 6144D38 72 RW working system preamp table
Collecting DT Infos completed
Detecting Phys Sct Size...
Result.................................. : 512
Any suggetions
 Post subject: Re: Model : ST9500325AS
PostPosted: April 25th, 2013, 12:51
Have sectors skipping? If yes, a lot?
Was thinking that if you have certain amount skipping, it can skip over a bad head, and resume imaging process on its own.
PostPosted: April 25th, 2013, 13:38
If i starts its copying all,after certain time by 4-5 mins ,after that ready states goes to continuous blinking DWF ERR.then unable to read .at this state if i turn off/n ON(F12)
starts copying(Like Loop)
