| seagate 7200.12 http://forum.hddguru.com/viewtopic.php?f=20&t=26111 |
Page 1 of 1 |
| Author: | y0k090 [ May 28th, 2013, 23:42 ] |
| Post subject: | seagate 7200.12 |
Hi Quote: Rst 0x08M No HOST FIS-ReadyStatusFlags 2002B001 ASCII Diag mode F3 T>/2 F3 2>Z HighPowerMode Spin Down Complete Elapsed Time 0.102 msecs F3 2>U HighPowerMode ExecuteSpinRequest Spin Up Complete Elapsed Time 3.763 secs F3 2>/t F3 T>m0,2,2,,,,,22 RW subfile error 201F RW subfile error 201F SIM Error 201F DiagError 0000500E Process Defect List Error R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 0025633B, File Error 000000D0 F3 T> please, how to fix thanks |
| Author: | hddguy [ May 29th, 2013, 8:39 ] |
| Post subject: | Re: seagate 7200.12 |
Quote: F3 T>/2 F3 2>Z HighPowerMode Spin Down Complete Elapsed Time 0.102 msecs F3 2>U HighPowerMode ExecuteSpinRequest Spin Up Complete Why do you do this? Quote: F3 T>m0,2,2,,,,,22 And why do you instantly run this command without checking the presence of of complications like non resident list? If this is a clients disk, I suggest you send to a professional. |
| Author: | northwind [ May 29th, 2013, 9:50 ] |
Another 7200.11 tutorial followed blindly for a 7200.12 ... |
| Author: | y0k090 [ May 29th, 2013, 11:10 ] |
hddguy wrote: Quote: F3 T>/2 F3 2>Z HighPowerMode Spin Down Complete Elapsed Time 0.102 msecs F3 2>U HighPowerMode ExecuteSpinRequest Spin Up Complete Why do you do this? Quote: F3 T>m0,2,2,,,,,22 And why do you instantly run this command without checking the presence of of complications like non resident list? If this is a clients disk, I suggest you send to a professional. I am using seagate HD doctor. I want to repair, do not need data. I can not check any public list. I can not load from HDD |
| Author: | y0k090 [ May 29th, 2013, 11:15 ] |
northwind wrote: Another 7200.11 tutorial followed blindly for a 7200.12 ... What is the command used to 7200.12 any signal you can give. I think it will get the error. |
| Author: | hddguy [ May 29th, 2013, 11:57 ] |
y0k090 wrote: do not need data. Why would you want to repair? chances are its under warranty, RMA it. |
| Author: | y0k090 [ May 29th, 2013, 21:22 ] |
hddguy wrote: y0k090 wrote: do not need data. Why would you want to repair? chances are its under warranty, RMA it. I need to fix it. I have followed the statements Salvationdata forum, but no success. |
| Author: | BlackST [ May 30th, 2013, 4:52 ] |
RW subfile error 201F RW subfile error 201F SIM Error 201F DiagError 0000500E Process Defect List Error R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 0025633B, File Error 000000D0 It is "something more" than usual problems , "internet fix" doesn't work in this state and also, in my opinion, is dangerous for data. Does SA read ? |
| Author: | hddguy [ May 30th, 2013, 5:06 ] |
The translator command was run instantly after spinup, this will never work and always produce error. |
| Author: | y0k090 [ May 30th, 2013, 5:36 ] |
hddguy wrote: The translator command was run instantly after spinup, this will never work and always produce error. This command is always used for the following cases: Quote: Rst 0x08M No HOST FIS-ReadyStatusFlags 2002B001 why it can not be used in this case. 70% success when using this command. the problem is there any other way, I was trying to test the command. results are not as expected. |
| Author: | y0k090 [ May 30th, 2013, 5:38 ] |
BlackST wrote: It is "something more" than usual problems , "internet fix" doesn't work in this state and also, in my opinion, is dangerous for data. Does SA read ? if the bad sectors in SA, how to fix, or no solution. Salvation is often said by the SA, but they can not provide a solution. |
