 Post subject: HCC545032B9A300 CS0B
PostPosted: August 19th, 2013, 7:41
I'm looking for salvationdata modules, nvram and .res from a working HCC545032B9A300 firmware PB3GCS0B (cinemastar drive)
TIA
 Post subject: Re: HCC545032B9A300 CS0B
PostPosted: August 21st, 2013, 16:31
Where does this drive come from?
PostPosted: September 14th, 2013, 6:43
This drive came from a Sagem receiver. It seems that I didn't need the res file as a hts5450 res is compatible. The firmware can only be accessed from sa-c.
I think the firmware is modified for sagem use. It powers in dco frozen with no possibilities to unfreeze the drive (copied sa-c configuration modules to sa-a and sa-b with no luck). Maybe changing the whole firmware will bring the drive to life or am I totally wrong? Does any of you has experience in such firmware modification with hitachi drives?
TYA
PostPosted: March 28th, 2014, 13:00
Anyone know how to unlock this drive ?
