Discussions related to SalvationData products
please help
August 11th, 2013, 11:25
hi
when i connect a drive to my hd doctor WD,
it shows busy and then no hdd
and busy no hdd
busy no hdd
and again and again
please help
Re: please help
August 11th, 2013, 16:28
Hi, get in contact with SD, not just the forum, but by email.
Re: please help
October 12th, 2013, 15:25
Hi, i'm having the same problem with a 2tb WD Green. i actually opened the hard drive without touching it to see if something is physically wrong.
Did you solve something about that?
Re: please help
October 29th, 2013, 15:41
If you hook it up and it remains perpetually busy after powering on, but before trying to read from HDD, then it is often a problem with the SA (e.g. bad sectors). If you get the issue after clicking load from HDD then you should load from file instead and then san the FW and ROM.
