Page 1 of 1
2TB WD erros in mods (006A,006F,0068,0069 and 0004 ).
Posted: February 15th, 2014, 4:26
by redseaksa
Hi Friends
I have this problem with 2TB WD20EARS-00MVWB0 erros in mods (006A,006F,0068,0069 and 0004 ).
I cannot access the data anybody can help please thanks
Re: 2TB WD erros in mods (006A,006F,0068,0069 and 0004 ).
Posted: February 16th, 2014, 4:50
by michael chiklis
The drive is detect in the computer bios?
Is detect in device manager in windows?
P.S.
mod 6F results always with bad CRC also on good drives, it's normal...
Posted: February 16th, 2014, 6:50
by michael chiklis
Did you try to read mods with sediv?
I had troubles reading mods on some WD drives with HD Doctor and WDR, but any problem with sediv.
Try with Sediv demo version, you can read ROM + mods (via ID or via ABA) and see if you still have those error:
http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
Posted: February 17th, 2014, 13:03
by redseaksa
Bios detect the hdd.But cannot access the data.
I used SD ,detect 006A,006F,0068,0069 and 0004 errors.
Posted: February 17th, 2014, 15:48
by michael chiklis
Have you tried to clone it in DE or with some dos toos as DMDE or Mediatools?
If cloning works but very slow everywhere on surface, then very likely hdd has bad sectors + relo list problem.
You can clear relo list in HD Doctor by pressing 'slow repair':
viewtopic.php?t=27905&f=1&start=0#p191573then you should been able to clone fast...
If it's not possible to begin cloning then most likely you have bad heads
Posted: May 23rd, 2014, 12:55
by gacpac
redseaksa wrote:Bios detect the hdd.But cannot access the data.
in 006F for most drives that module can be bad even in new drives so it doesn't matter
