HD Doctor for Seagte is the 2 beep
http://forum.hddguru.com/viewtopic.php?f=20&t=28086
Author:  hvd [ March 3rd, 2014, 6:05 ]
Post subject:  HD Doctor for Seagte is the 2 beep
Hello
I have the problem with diques Segate Momentus ST9500325AS hard 2.5.
The hard drive works under Windows 2.5.
I used the HD Doctor for Seagte 6 software under windows 7 32bit and when I use the Power ON button on the HD Doctor for Seagte 6 so HD Doctor for Seagte is the beep makes two beeps.
HD Doctor for Seagte is compatible diques the Segate Hard 2.5 because I was with 2 other seagate hard drive so it is the same?
I used the jumpe JP4.
2.5 hard disk image here
http://nhaconline.free.fr/Sal/Seagate.avi
There is no problem with HDD 3.5
Thank
Author:  michael chiklis [ March 4th, 2014, 4:41 ]
Post subject:  Re: HD Doctor for Seagte is the 2 beep
Don't power the sata controller from HD doctor output!
Give power to the controller directly from the computer power supply.
Don't use Doctor output!
Also, are you sure you have properly connected the TTL connector to the drive, from the photo i see it is upside down (i think)
Author:  jerovsek [ March 4th, 2014, 6:17 ]
1. external adapters doesent work well with HDD4Seagate. The best way is tu use computer power supply.
2. turn TTL adapter oposite
Author:  hvd [ March 4th, 2014, 13:32 ]
Hello
Yes it works with power pc
thank you
