 Post subject: Recovering data from Burned PCB with integrated ROM in MCU
PostPosted: March 24th, 2014, 13:47
i was reading about regenerate ROM option in HD DOCTOR FOR WD.
I have a WD3200AAJS with a not working PCB that have the rom integrated in the MCU. This repairs are suppose to be done with a rework Station desoldering the MCU and migrating to the donor PCB.
So, actually i know i can read mods using a donor PCB in low access mode and also test heads and stuff.
My question is. How can i actually regenerate the rom because i don't think that i can simply click on the button "REGENERATE ROM"
i also was doing some research but those cases are when you have a corrupted rom. In this case i don't have the ROM.
Sorry for asking but any answer will help me a lot.
Regards,
 Post subject: Re: Recovering data from Burned PCB with integrated ROM in M
PostPosted: March 24th, 2014, 14:36
I don't see why HD Doctor couldn't automatically regenerate the ROM, but here is my take on the underlying process:
Regenerating a WD ROYL ROM from SA MODs:
viewtopic.php?f=13&t=28249
PostPosted: March 24th, 2014, 15:53
Well,
So it's safe to use the regenerate rom?
I haven't tried to click the button on regenerate because i never had to use it and now just to be safe that i was basically asking.
PostPosted: March 24th, 2014, 15:56
I'm not a DR professional, but I have heard that some models are not correctly handled by HD Doctor, resulting in ROM corruption. However, if you are using an expendable donor PCB, then it can't hurt to try.
PostPosted: March 24th, 2014, 16:11
Good Answer.
I have more than one PCB actually. so i think i'll try
Thanks for the help :)
PostPosted: March 24th, 2014, 17:04
BTW, I should have added that in some cases the SA modules are empty, ie they will contain the string "NOT INIT". In such cases I believe it may be possible to regenerate adaptive data from selfscan logs, but I'm not a data recovery professional.
PostPosted: May 23rd, 2014, 12:59
Thanks for the help
Backup rom modules and uploading back through SD Tool
It worked perfect
