| WD3200AAJS http://forum.hddguru.com/viewtopic.php?f=20&t=28776 |
Page 1 of 1 |
| Author: | ruchiinfotech [ June 4th, 2014, 3:52 ] |
| Post subject: | WD3200AAJS |
Hi all.. i need sum help to solve a hdd . i have wd3200aajs which dose not get detect in bios . as i connect it to hdd doctor wd it shows continuous BUSY for 3-4 minutes than it goes NO DEVICE also motor stops. i swapped the PCB with donor PCB and patient ROM but still the problem remains same . i am not able to understand how to start the troubleshooting . pls advice |
| Author: | MindMergepk [ June 4th, 2014, 4:54 ] |
| Post subject: | Re: WD3200AAJS |
seems to be a head problem |
| Author: | thatdellguy [ June 4th, 2014, 5:10 ] |
If you're not sure on which steps to take next and this is a customer's drive, consider sending it to a professional. |
| Author: | pcimage [ June 6th, 2014, 16:04 ] |
MindMergepk wrote: seems to be a head problem Yes, almost certainly, |
