 Post subject: WD3200AAJS
PostPosted: June 4th, 2014, 3:52
Hi all..
i need sum help to solve a hdd . i have wd3200aajs which dose not get detect in bios . as i connect it to hdd doctor wd it shows continuous BUSY for 3-4 minutes than it goes NO DEVICE also motor stops. i swapped the PCB with donor PCB and patient ROM but still the problem remains same . i am not able to understand how to start the troubleshooting . pls advice
 Post subject: Re: WD3200AAJS
PostPosted: June 4th, 2014, 4:54
seems to be a head problem
Data Recovery Pakistan
PostPosted: June 4th, 2014, 5:10
If you're not sure on which steps to take next and this is a customer's drive, consider sending it to a professional.
PostPosted: June 6th, 2014, 16:04
Yes, almost certainly,
Users browsing this forum: No registered users and 46 guests
