| Barracuda help http://forum.hddguru.com/viewtopic.php?f=20&t=29515 |
Page 1 of 1 |
| Author: | S.K. [ September 12th, 2014, 8:16 ] |
| Post subject: | Barracuda help |
I got a barracuda 2TB drive model no ST2000DM001.Drive gets ready and F3 prompt is reached. but the time I try to read any sector, the drive status changes to error. I tried mo,2,2... and m,6,2... commands but still same problem.When I try to fix sector access command fro 7200.11 menu , error is there saying could not get drive parameters. Here is terminal message- Boot 0x40M Spin Up Trans. Spin Up SpinOK TCC:0023 (P) SATA Reset ASCII Diag mode F3 T>m,6,2,,,,,22 Max Wr Retries = 08, Max Rd Retries = 32, Max Iterations = 3A, Max Certify Rewrite Retries = 29DD (DOS) File Save (DOS) File Save Update HPA Cap and Save User Partition Format Successful - Elapsed Time 0 mins 00 secs F3 T>m0,2,2,,,,,22 Max Wr Retries = 08, Max Rd Retries = 32, Max Iterations = 3A, Max Certify Rewrite Retries = 29D1 (DOS) File Save (DOS) File Save User Partition Format Successful - Elapsed Time 0 mins 00 secs F3 T> ASCII Online mode TCC:0023 [b] When I try to detect the drive then this is the error Dither Dither ABORT! SenseCode = 87270000 ReadyStatusFlags = 0002E1E0 ABORT! SenseCode = 87270000 ReadyStatusFlags = 0002E1E0 Please suggest what to do? Thanx |
| Author: | mikail13 [ January 12th, 2016, 11:27 ] |
| Post subject: | Re: Barracuda help |
Same disk, same message.. any idea? ASCII Diag mode F3 T>m0,6,3,,,,,22 Max Wr Retries = 08, Max Rd Retries = 32, Max Iterations = 3A, Max Certify Rewr ite Retries = 29DD (DOS) File Save Update HPA Cap and Save User Partition Format Successful - Elapsed Time 0 mins 00 secs F3 T>/1 F3 1>N1 Clear SMART is completed. F3 1> |
| Author: | mikail13 [ January 12th, 2016, 11:45 ] |
F3 T>i4,1,22 F3 T>m0,6,3,,,,,22 Max Wr Retries = 08, Max Rd Retries = 32, Max Iterations = 3A, Max Certify Rewr ite Retries = 29D1 (DOS) File Save User Partition Format Successful - Elapsed Time 0 mins 00 secs F3 T>/1 F3 1>N1 Clear SMART is completed. HDD came partitions type is not seem and data couldn't seem. |
| Author: | mikail13 [ January 12th, 2016, 12:15 ] |
Success.! Because of HDD parttions is ext3 windows can't recognise it. you must clear G-List. |
