 Post subject: WD3200BPTV Slow reading
PostPosted: October 7th, 2014, 9:24
I have a WD3200BPTV 320Gb HDD. I can access the partitiions under DC but the data read is very slow. When I hard restart the gives me a few seconds of normal read time but then it comes to a dead slow. I suspect a head problem. Is there any other ideas or ways I can speed up the process without changing heads/parts?
Thanks,
Mario
 Post subject: Re: WD3200BPTV Slow reading
PostPosted: October 7th, 2014, 9:35
If you stops the drive for a while (for example 30 min) and you reanude reading, you get more time reading normal?
PostPosted: October 7th, 2014, 10:24
It will read normal for a second or two then dead slow.
Thanks.
PostPosted: October 7th, 2014, 10:28
Thanks.
but: doing this too?
PostPosted: October 9th, 2014, 17:14
Doesn't your tool have an option to "deal with slow responding"?
