HDD GURU FORUMS
http://forum.hddguru.com/
WD3200BPTV Slow reading
http://forum.hddguru.com/viewtopic.php?f=20&t=29681
Page 1 of 1
Author:  datasafe [ October 7th, 2014, 9:24 ]
Post subject:  WD3200BPTV Slow reading
I have a WD3200BPTV 320Gb HDD. I can access the partitiions under DC but the data read is very slow. When I hard restart the gives me a few seconds of normal read time but then it comes to a dead slow. I suspect a head problem. Is there any other ideas or ways I can speed up the process without changing heads/parts?
Thanks,
Mario
Author:  hhddrec [ October 7th, 2014, 9:35 ]
Post subject:  Re: WD3200BPTV Slow reading
If you stops the drive for a while (for example 30 min) and you reanude reading, you get more time reading normal?
Author:  datasafe [ October 7th, 2014, 10:24 ]
It will read normal for a second or two then dead slow.
Thanks.
Author:  hhddrec [ October 7th, 2014, 10:28 ]
Thanks.
but: doing this too?
Author:  fzabkar [ October 9th, 2014, 17:14 ]
Doesn't your tool have an option to "deal with slow responding"?
http://www.phpbb.com/
