 Post subject: Service for remote reflashing/converting SAS HDD/SSD
PostPosted: February 1st, 2021, 8:45
Continuing on this topic:
https://forum.hddguru.com/viewtopic.php?f=22&t=39927
The issue of reflashing and unlocking disks for use in various equipment is of constant interest, so I am posting some details.
There is a possibility of converting civilian versions of HDD and SSD disks into OEM models, or from models of one OEM vendor to another.
All work is done remotely.
Currently, this option is available for SAS HDDs from Seagate and SAS HDDs and SSDs from WD-HGST.
In this case, the full microcode is loaded into the disk, and not only the name is changed.
The finished disk turns out to be fully functional, supports the specifications of the target equipment without restrictions and goes through the procedure for updating the microcode by standard means.
List of OEM vendors: HP, 3PAR, IBM, Lenovo, Netapp, Dell, EMC, Cisco, Fujitsu, Sun, etc.
Supported HDD models (the name of the highest "civilian" model is indicated here, but lower models and OEM modifications are also supported):
ST9300603SS (Savvio 10K.3)
ST9600204SS (Savvio 10K.4)
ST9600205SS (Savvio 10K.5)
ST900MM0006 (Savvio 10K.6)
ST1200MM0007 (Enterprise Perfomance 10K.7)
HUC106060CSS600 (Cobra-D)
HUC109090CSS600 (Cobra-E)
HUC101212CSS600 (Cobra-EP)
HUC101818CS4200 (Cobra-F)
ST9300653SS (Savvio 15K.3)
HUC156060CS4200 (King Cobra-F)
ST32000424SS (Constellation ES.1)
ST33000650SS (Constellation ES.2)
ST2000NM0001 (Constellation ES.1)
ST4000NM0033 (Constellation ES.3)
HUS723030ALS640 (Mars-K)
HUS724040ALS640 (Mars-KP)
HUS726060AL5210 (Aries-HC)
HUH728080AL5200 (He-8)
HUH721010AL5200 (He-10)
ST3600057SS (Cheetah 15K.7)
HUS154545VLS300 (Viper-BP)
HUS156060VLS600 (Viper-C)
Supported SSD models:
HUSMM8080ASS200 (Sunset-Cove MLC)
HUSMM1616ASS200 (Sunset-Cove Plus)
Here are those models for which there are ready-made and proven solutions. The real list of supported models is much longer.
In addition, for most models it is possible to "download the firmware" from your sample (if available) and upload it to the donor disk.
As an example, a disk from the Hitachi storage system HITACHI-DKR5E-J1R2SS can be turned into a "civilian" HUC101212CSS600 or EG1200FDNJT for HP systems.
Or we can make IBM-D050 ST900MM0006 FRU 00AR326 from the "civilian" ST900MM0006 disk.
Or from EMC-SSD HITACHI-HUSMM148-CLAR800 we can make HP-MO0800JEFPB.
To work from your side, you need a Windows 7 PC (preferably x64 version). An Internet connection with a static white IP is required for RDP to work. The PC must have a SAS HBA card installed (preferably something "simpler" from the LSI 30xx or LSI 92xx families).
With a large quantity, for convenience, you can connect a JBOD shelf.
In addition to the usual procedures for unlocking and flashing, long-term partnerships around the world are also interesting. You can see for yourself: a minimum investment is required from you.
E-mail for communication: evrus.lab@gmail.com
 Post subject: Re: Service for remote reflashing/converting SAS HDD/SSD
PostPosted: May 24th, 2022, 15:25
Support for Seagate 12Gb/s (Seagate Exos) SAS drives is present now:
ST1800MM0xx8 Enterprise Perfomance 10K.8 (10E1800 Thunderbolt)
ST2400MM0xx9 Enterprise Perfomance 10K.9 (10E2400 Skybolt)
ST600MP0xx5 Enterprise Perfomance 15K.5 (15E600 ValkyrieBP)
ST900MP0xx6 Enterprise Perfomance 15K.6 (15E900 Kestrel)
ST6000NM0xx4 Enterprise Capacity 3.5 HDD 7200.4 (Makara)
ST8000NM0xx5 Enterprise Capacity 3.5 HDD 7200.5 (7E8 MakaraBP, Makara Plus)
ST10000NM0xx6 Enterprise Capacity v6 HDD & Exos X10 (7E10 Tatsu)
ST12000NM0xx7 Exos X12 (Mobula)
ST14000NM0xx8 Exos X14 (MobulaBP)
PostPosted: September 18th, 2022, 13:14
Added support for WD-HGST 12Gb/s SAS and 6Gb/s SATA drives:
HUS726T6TALxxxx (Vela-A HC310) - both SAS & SATA
HUS728T8TALxxxx (Vela-AP HC320) - both SAS & SATA
WUS721010ALxxxx (Vela-AX HC330) - both SAS & SATA
HUH721010ALxxxx (Libra-HC10 HC510) - both SAS & SATA
HUH721212ALxxxx (Leo-He12 HC520) - both SAS & SATA
WUH721414ALxxxx (Leo-He14 HC530) - both SAS & SATA
PostPosted: December 7th, 2023, 10:33
interested, I would have 7 x HUH721010AL to flash..
PostPosted: January 1st, 2024, 1:31
Hello, I sent an email super interested, I want to get this taken care of ASAP. I have HGST HUC101818CS4204. Is this possible to be vendor unlocked?
PostPosted: September 18th, 2025, 16:48
Interested.
