 Post subject: SAMSUNG HDD HD253GJ
PostPosted: March 9th, 2018, 2:25
WHAT IS A PROBLEM THIS HARD DISK ??
WHEN POWER ON SHOW TERMINAL LOG :
*PA VID=0000 PN=0004 Rev=0001- 785x Found*PA VID=0000 PN=0004 Rev=0001- 785x FoundChipRev = 63B0U
S_0
RV En Sensor Circuit
En Shock Sensor Circuit
SO_1
SpinStartUp: mcSpinRPM = 0
RPM at Handoff: 634
Temp : 29 degC
eng>SpinOk
mS1 00000003
SK C:135360 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x14
Selective MARC NX Loaded
ResoTable Loaded. Rev:0x01
Ovly loaded to 0x0001CD00
Ovly loaded to 0x1005B800
FdtTable Loaded. Rev:0x02
| 19 | RLIST | 2 | 0 | 256 | 1140 |
Reading Serial Num Pass
Up MC
TgtCyl: 2032
Hd: 0 Zn: 0 Avg.:- 232
TgtCyl: 264349
Hd: 0 Zn: 1 Avg.: 101
SVCAL(0080,0000)-->PASS
>>InsituStart: t=778, c=30
GeoId = 49, Idx=49
fodstep: 00000062 dgain: 00000064
GeoId = 49, Idx=49
fodstep: 0000006B dgain: 00000066
GeoId = 49, Idx=49
fodstep: 0000006E dgain: 00000062
>>Flag=0000028B BadHd=0000 dFod=001C (t=807 c=30)
RecordValid Fail : 0007643D 0007E41D
VOP!
PK_4 C:238004 H:0
VOP!
PK_4 C:238004 H:0
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
eng>
 Post subject: Re: SAMSUNG HDD HD253GJ
PostPosted: March 9th, 2018, 3:35
Looks like bad ALIST.
PostPosted: March 29th, 2022, 19:58
S_0
SO_1
RPM at Handoff: 634
Temp : 29 degC
eng>SpinOk
mS1 00000003
SK C:135360 H:0
Up MC
TgtCyl: 2032
TgtCyl: 264349
GeoId = 49, Idx=49
GeoId = 49, Idx=49
GeoId = 49, Idx=49
VOP!
PK_4 C:238004 H:0
VOP!
PK_4 C:238004 H:0
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
LED 1A04
eng>
I had same issue.
my first donor was weak. Died at 30%. Tried 2nd perfect donor . And got this error.
After some research, Decided to use LE command. And case solved.
Sexy Womans from your town
cron
